New to revit
    New to revit
    How do I get started
    Sent from my P8W using Tapatalk
    Buy a license, buy a book, get on uTube, start modeling something, then when you run into issues you ask questions here
      I have but none of the families are loading n the four elevation cameras are not showing?
        content not loading during install is a common problem. See this for help
        edit: and if by elevation cameras you mean elevation markers (the box with a triangle at one to four sides) then you need to check Visibility/Graphics (type VG) then go to Annotation tab and make sure that Elevations is checked
        oh, and welcome to the forum!
          How do I post a new thread?
            Go to the subforum you wish to add a thread to, and hit the post new thread, top left. Easy as.
              don't see post new thread, went to revit architecture....
                Start with the architectural template not the construction template.
                  Bit puzzled tom. You seem to have started heaps. Maybe the admins could help.
                    Are you not seeing this?
                    Dave Plumb
                    BWBR Architects; St Paul, MN
