Mass modeling & reference lines & parameters
    Hi everyone,
    I am new to Revit. I have two questions about mass modeling & parameters.
    Please check the attached file. I have two lines at the upper part and they are working well with the defined parameters. The intended use here is the lines to move due to the changes in the "angle", "d1" and "d3" length values. Although I defined the same parameters for the lines at the lower part, lower part lines did not work.
    1. What should I do to make them work?
    2. I know that I should use reference lines instead of model lines; however I can not give dimension to reference lines and make them work. What should I do to make them work as reference lines?
    Anybody has any idea?
    Thank you.
    Seda
    Thanks, it is solved now. The key is to use multiple reference lines overlapping and distributing the parameters to them to avoid one ref. line have more than one parameter.
