I've got two 9 story office buildings fully modeled with curtain wall. I received an email from the Contractor this morning that says "due to FEMA requirements the Architect is changing the PBP elevation from 0'-0" to - 1 1/8"". And goes on to ask all of us subcontractors working in Revit to do the same. In my mind, if I change my PBP elevation to -1 1/8" to match the Architect's models all that does is just raise the project up in 3D space 1 1/8". Floor to floor differences are not changing so my Level 1 that was +45" is now +46 1/8" and all other levels above are also 1 1/8" higher. I see no issues with doing this but wanted to check with those that have more experience with project coordinates than I to make sure. Am I missing anything?
Change PBP elevation?
So....I was just told last week that all levels of the high-rise over the Ground Floor need to be lowered by 1" at end of SD. So I raised the Ground & Basement (parking) levels up by 1", then unlocked the PBP; selected the "Relocated Project" tool & moved it down by 1", then I moved the unlocked PBP back up to match Ground level & locked it up again. +20 levels with Unit groups & stuff gave too many issues (was developed before they hired me, so I had patched it up with best practices but still too messy for my standards & other happenings going on to fully spruce it up, but I digress), & every few floors it was a different plate/layout. It worked like a charm.
Originally posted by Ning Zhou View PostI'm retired, if you don't like it, go around!
Hi everyone
Just took over a project that was assigned to another person, and the elevation levels doesn't seem to be correct. In the attached...February 27, 2015, 02:06 AM -
Okay, so I am working on a building's Curtain Wall which has a concave wall along one side. I have decided to create a new project to make a developed...February 26, 2014, 07:01 PM
Hey all
I have a 34 story condo and I have to change the elevation of the ground and 6th level and have all other levels move up respectfully...
July 4, 2013, 06:15 PM -
I am working on a file given to me from another consultant. The file has all of the levels based on the surveyor's elevations (i.e. the FF for the first...December 10, 2013, 08:16 PM
Hi All, I'm having trouble with a couple of Levels in my Revit 2015 project. The elevation value of 2 of my Levels is not showing an integer value, and...September 1, 2015, 04:26 AM
