First major assignment with my firm, got a couple of queries that would help make my models run smoother.
Firstly - how can I add Parameters to an IFC element, in the same way that i would a component element. If this is not possible, then is there a way to explode the IFC element to make it editable?
Secondly - is there a way to blanket add a system of parameters to every component within a project. For clarification I have a kitchen with around 40 components (half of which are imported IFC, half are constructed models) each of which needs electrical, gas, and water requirements added into them. I wondered if there is a way to systematically add a range of parameters to the revit model itself, which would attach to each component individually.
Hopefully there is a way to achieve what im thinking of - otherwise I will have to revisit each component, and add in 10 custom parameters for each.
Thanks
Thanks
