Good evening everyone,
I'm running sloped piping in fab parts in Revit 2017 and can't figure out why it doesn't look the way I'd expect it to look.
My plan is set to "hidden line" visual style so that lower objects show up with broken lines as they pass under higher objects - this is what I expect from Revit. However, I'm finding this doesn't happen with Fab Parts. For instance, there are floor drains below the pipe, but the pipe looks like it runs below the floor drain (ie, the pipe's lines break to reveal the entire floor drain).
Also, I want my insulation to be 100% transparent, but under MEP Fabrication Pipework category, the insulation subcategory doesn't have a separate transparency setting. So I created a filter for it and set it to 100% transparent.
When I do that, pipes that cross at different elevations don't display properly. For example, my pipe is running in the 4,500-5,200mm elevation zone. I model another line below it running perpendicular in the 3,200-3,600mm elevation zone and when they cross, the higher pipe looks like it runs below the lower pipe.
When I zoom in and out, the pipes look good. But when I stop zooming, it looks all wrong.
When I use native Revit, this never happens, so I'm a little stumped. Particularly because I have to get some new guys on gravity tomorrow.
Anyone else deal with these issues?
Thanks
Thanks
