Wall with two different finish materials over its height ?
    Is it possible to model a wall to have two finishes, split at a specific height. Or to have a finish only over a certain height, with the underlying material being visible for the remainder ?
    In case, what parameters would achieve this?
    I'm thinking within the same level, so modeling separately by level isn't what I'm looking for.
    Yeah....in the same wall section edit window where you can add sweeps and such you can split materials and change them to a different material...
    Take a look here: https://knowledge.autodesk.com/suppo...7FAE1-htm.html
