Same floor multiple levels
    Hi, I'm recently moved from Autocad to revit MEP, so every day is I learn something different (the struggle).
    So, I'm developing a project and on some floors there are multiple levels, when i place the electrical components and move their height to fit the level (example floor 8 there is a standard height, and some stairs that lead to level 50 cm below the standard height), the components vanish into the floor below.
    Can someone help please.
    Thanks in advance!
    Thanks in advance!
    Adjust View range or create plan region.
      Thanks, I tried adjusting view range and it worked!
