Hello,
I have an issue with Revit 2017. I can dimension gridlines on plan. When I cut a section, I see the gridlines that means the section is cut perpendicular to the grid lines. For some reason when I pick the gridline to dimension, I get this barred symbol. Has anyone encountered this?
Thank you
R
Thank you
R
