Adding Sheet Numbers and Sheet Indexes
    Does anyone know of a slick way to force a sheet number like A274.1C to follow A274C in the sheet index?
    Bettisworth North
    Sub order parameter
    Sort by Discipline, Discipline Order, Sub order, sheet number
    Have to use it because Civil has funky numbering that just doesn't make sense...
    Oh...and don't put in a number in the suborder unless you absolutely have to. Once you do it to one sheet, you have to do it to all of them in that particular order.
      Originally posted by MPwuzhere View Post
      Sub order parameter
      Very nice, however, our index also sorts by Volume so I don't have available fields for Sub Order. I am stumped, unless I simply separate the Index on the sheet and slip in an index that only includes the odd numbered sheet.
      Just finished the index using your suggestion of a suborder. Created a new index that filtered and sorted by suborder and slipped it in line with the major index. Looks good and not much effort. Thanks for the heads up!
      Last edited by Charles Karl; October 4, 2017, 04:47 PM. Reason: Update was successful
      Bettisworth North
        You may want to use a single parameter to combine your sorting, so each sheet gets a single "combo" value to sort by. Something along the lines of <discipline order><sub order> in one parameter. You would have to coordinate this manually (use schedules and calculated values to help assemble the value from other parameters), or use Dynamo to do the legwork. I think you could eliminate sorting by Sheet Number at that point, as the combo value could handle that in the <sub order>. This would allow you to sort by (and get title labels for) Volume, Discipline, and one other value in addition to your "combo" parameter.
        Chris Ellersick
          I use 1.) Disc # - 2.) Disc (as Header) - 3.) Publish Order (by series set, if needed) - 4.) Sheet #.
          My Disc # is formatted with "(No._Disc Name); ex, 00.0_Arch, 06.0_Arch, etc... where the 00.# could help me squeeze in Interiors or Demo or others wherever the PM deems them necessary.
          This helps me for the most part use only 3 parameters & not need "Publish Order", but for special circumstances (rare).
            Now that is creative!
            Just got to thinking that I can simply use publish order to do the same thing...sweet!
            Bettisworth North
