I'm trying to figure out how to push data from the curtain Wall, down into its individual curtain Panels. In the example below, it works fine if i change that code block to 0; and run the graph, then manually change it to 1, then 2, and keep going till i go through every curtain wall in the project.
I'm sure my problem has to do in my attempt to use the list.count to help generate the list. Any insight would be great, my knowledge of complex list manipulation is pretty weak.
