Hello everyone, my question is for anyone who is familiar with BIM standards and LOD specifications and it's best practises , is it recommended to have a wall containing all layers as a one assembly , or have every layer separated on a unique object , am talking BIM standards wise , probably the answer will be having it in a one object , but why?
about revit wall (create parts) and BIM standards
*If* it's a standard, I'd be surprised and I don't believe any LOD will dictate how to model, just what's required.
A good discussion about walls as assemblies vs walls as a kit of parts.
It also depends on where you are in the food chain. Are you a designer? A contractor? A sub? That could dictate your requirements and what's needed from a model.Chris Heinaranta | Architectural Technologist
More reasons why LOD should be kicked to the kerb!
Originally posted by arcosamaq View PostI was checking some LOD400 and 500 specifications , U values and fire rating information call for a full wall assembly n material calculation can be performed with full wall assemblies but easier with separate walls
The model is, and can be, whatever - so long as Information can be gleaned to meet the I part of the BIM requirements.
The key distinction here is that a model, Revit or otherwise, is not the/a BIM, so there's absolutely no argument, from any LOD "standard", that ALL of the Information should reside within a model. A technical report of, with certificates for, fire resistance tests; spreadsheets of U-Value calculations and synthesised thermodynamic models? All of these things are all alien to Revit - so in the same way I do not expect to find my services contract ever delivered to me in an .rvt, so should NO ONE expect the reverse in any shape or form.
The unadulterated hypocrisy and bias of the standard makers is, sadly, all too evident when you read most of them - so pay them no mind.
Model what suits your delivery requirements.
If someone picks your model up down the line and haven't themselves deflected an over-zealous LOD500 requirement, that is not your problem.
And yes, I did just suggest "chuck it over the fence" - despite all of us supposed to be cute in the spirit of collaboration - but, well, as you can probably work out I don't buy any of that BS either.
Hello bimmers!
A long time ago when I first started Reviting, I used to model ALL walls (floors and roofs) as once single object "The...June 24, 2019, 03:06 AM -
Hey all -
Here is the scenario. I have modeled an existing building for a renovation project. The Owner has made the decision to re-skin...June 5, 2018, 07:17 PM -
Hey everyone,
I've got a problem with my walls showing up incorrectly.
Given that we're using a one-model...September 9, 2016, 10:10 PM -
okay try this: open a new project- (default template or no template)-o
draw a piece of wall- go into wall assembly and add a couple of layers...February 14, 2012, 03:07 AM -
We're looking at doing a decent sized project with wall finishes modelled separately to structural walls - what do people who use this method do when...July 1, 2016, 10:39 PM
