How do i get the tag leader to align with top label?
    Please see image attached.
    how can i achieve this?
    thanks
    andy
    add an invisible line to your tag family that extends upwards an equal distance as the bottom row of text. The leader will attach to the vertical middle of the tag family.
      thanks. It worked. :thumbsup:
        And then go vote up this Revit Idea
        https://forums.autodesk.com/t5/revit.../idi-p/7364191
        So that Autodesk fixes it right, without dumb workarounds like that.
        Dave Plumb
        BWBR Architects; St Paul, MN
