Hi, the section head and tail are a very weird bubble and block - what is that? Seriously what planet uses that? It isn't in any way standard. I want simple arrows that indicate which direction the section is taken and with the section information (A-A or B-B or I-I or II-II etc) I don't want a silly bubble and a black line at the bottom. How in hell can I change this to simple arrows and reference view (A-A etc)?
Section bubble head change to arrows
you can just edit the family. get the type properties of your section and it should say which family it uses for the bubble and you can pick another one there.Company Website: www.deurloobm.nl
Originally posted by jdmorrisn View PostHi, the section head and tail are a very weird bubble and block - what is that? Seriously what planet uses that? It isn't in any way standard.Motorbike riding is one long bezier curve
Originally posted by jdmorrisn View PostHi, the section head and tail are a very weird bubble and block - what is that? Seriously what planet uses that? It isn't in any way standard. I want simple arrows that indicate which direction the section is taken and with the section information (A-A or B-B or I-I or II-II etc) I don't want a silly bubble and a black line at the bottom. How in hell can I change this to simple arrows and reference view (A-A etc)?
It's not that hard to change them, either. But just because you don't use it doesn't mean it's not a standard or is completely bizarre. It just means you haven't seen it before. Nothing more.
Aaron Maller
Director
Parallax Team, Inc.
Well I'm from Europe, UK and it isn't standard here. And whether a lot of the planet do or don't use it - in europe it is completely alien. I didn't pay attention to the fact that the symbol is non-european. I am using Metric US which might be the problem (since Metric UK came with absolutely zero families) but I have no other option for families in the annotation folders available to change it to as suggested and I am not that well versed at changing this family without probably screwing up its settings/ parameters.
Originally posted by biff View PostI would assume that someone else here from UK EUROPE would be able to help you out then. Is what you are wanting a standard look there? If so, go on brits, be a sporting chap or lass and throw the OP a section head.
thanks Chris (cellersick)I'm retired, if you don't like it, go around!
Originally posted by jdmorrisn View PostWell I'm from Europe, UK and it isn't standard here. And whether a lot of the planet do or don't use it - in europe it is completely alien. I didn't pay attention to the fact that the symbol is non-european. I am using Metric US which might be the problem (since Metric UK came with absolutely zero families) but I have no other option for families in the annotation folders available to change it to as suggested and I am not that well versed at changing this family without probably screwing up its settings/ parameters.
Dropping the rhetoric and just asking for help making the components you need (but don't have) will save everyone time, in the future.
Aaron Maller
Director
Parallax Team, Inc.
Originally posted by biff View PostIf so, go on brits, be a sporting chap or lass and throw the OP a section head.
Mate, seriously, we don't have a standard section head in UK. Even BS EN ISO 9431 doesn't dictate one.
Originally posted by snowyweston View PostAlas I only work in a little village called Clerkenwell where we only have a couple of hundred or so architectural practices in the area, so I can not really speak with any authority for the UK as a whole; and since collectively we are generally a bunch of backward Europhobes, I tend not to get too embroiled in dealings on the mainland; but having worked with a good few of the larger firms from around our area and close by, some whom appear to be informed by a smidgen of international experience, I would like think I have gleaned enough from their ways and, much like all of them, I am quite content using a form of section head akin to the one packaged OOTB with Revit, albeit with minor variations, because you know, we quaint little villagers like to fuss about with lineweights and stuff.
Good evening, I'm an alien.
Either way I have modified the existing section head to provide the result I need, thank you.
I have a drawing in which I would like to have two different section head types. I created a new section category (timber section) but this does not allow...January 14, 2016, 03:07 PM
What defines the intersection of the section family head and the section line? I have been tasked with enlarging the section head circle slightly to...
January 22, 2016, 03:21 PM -
Hello all,
This is my first post here and I appreciate any and all help you might be able to give me in advance.
I've been...-
February 11, 2016, 03:40 PM -
Hi all,
Been trying to figure out the solution to this myself but exhausted my limited knowledge so thought I'd ask for some help.
September 21, 2016, 10:04 PM -
Can anybody help me with having one section line where one side is straight and other side is angled 45 degrees. this all going to be as one section.May 11, 2016, 04:02 PM
