Model fill patterns
    Model fill patterns
    Is there a way to override a model fill pattern to an element instead of drafting pattern? I am trying to assign a tiles pattern to a wall elevation but only the drafting patterns are selectable. The problem with using drafting patterns is that they remain at scale 1:1.
    So you are trying to change the hatch used in the material? I use Model patterns for those all the time (or actually I only use model patterns. So, I'm guessing you are trying to do something else. Can you explain a bit more?
      It can be done by editing the txt file of the .pat file to include from what i remember a line stating model, preceded by a hash or other symbol. If you do a search here you should be able to find the exact process. I always have to look it up again every time i do it.
        The HatchKit Add-In for Revit can create a new drafting or model fill by scaling from a fill that is already within the project.
        Hugh Adamson
        Cadro Pty Ltd
          It is a missing tool from revit's standard program.
            I guess the proper way is to assign the pattern directly to the finish material of the wall type, and in order to change the pattern, instead of overriding it, you should create a new wall type. I just thought I could avoid this step!
              What I tried to do, is click on a wall in elevation, and click on override graphics -> by element. When you do that, in surface pattern it only allows you to choose from drafting fill patterns.
                go to the wall properties, and choose a model pattern from the choices available, for the exterior layer.
                  Well, I won't say you should never do that, but NEVER DO THAT !!
                  In the end you will not know which wall has what hatch on it and you will have all sorts of issues. If you wall needs another hatch, make another wallstyle.
                    Ok I will go for a new wall type then
