Revit Server Administrator 2016
    Can Anyone using Revit Server provide some insight to why a model size would see such a reduction is cashed files just from one sync to another. Could it be that an end user is syncing with only the start view open? Is there a correlation between having several views or sheets open while syncing and number of cashed files on RS?
    Bettisworth North
    I too would like to know. I have asked Autodesk, but they have been vague why the cached files fluctuates and sometimes balloons. The older versions of Revit Server used to start with a new set of cached files after re-creating a model, but the new versions i think retains them.
      I create a new central weekly, and I can tell you that at least for this model, that we see a reduction of at least 100mb, however, it doesn't take long to see cashed files stack up again.
      Bettisworth North
        This could be anything from someone running a compression on the main file, addressing warnings (if you have a TON of warnings this could add megabytes of logs to your file) or even detaching the central and re-saving it (getting rid of save points, save comments, logs, logs, logs).
        It could also be a conscientious employee purging the file of evil DWGs... >_>
          I'm going with the "someone clicking Compress"....former BIM Manager of mine said to never click that button... I still don't even though I dont work there anymore.
            Did anyone crashed? Transfer file is what you really need to keep an eye on
            Loading...
