elevation tags not visible
    I am working on a project, where I create callouts of smaller parts of the floor plans to detail individual rooms. In these new plan views I am creating interior elevation views, with the elevation tag shown on the plans.
    Today I have created a new plan to detail another room. When I try to add elevations, by clicking on the plan to insert the elevation tag I get this message "None of the created elements are visible in Floor Plan: GF LAUNDRY View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
    The elevation view appears in the list of interior elevations, but the elevation tag is not shown on the plan. I use the "reveal hidden elements" tool, and again it doesn't appear as a hidden element. I have checked the view template and the elevation category in the annotations is checked. But I already have other plans in the same project, where the elevation tags are visible and they are using the same view template. I have no plan regions in the project.
    What else can be wrong?
    Did you check the "Hide At Scales Coarser Than" parameter? Sometimes that can be the result of a hidden section mark or elevation mark. Since the elevation has been created it might be good to check a different plan to see if the elevation mark is there. You can change this parameter by clicking on the elevation tag or going to the view.
    Hope this helps.
    T-
      Thanks taylor.odell. Actually, I can't find this parameter in my views properties. I am working on Revit 2017. Can you guide me a bit more?
        It's not a property of the View. It's a property of the Elevation Tag.
        You have to click on the "wing" (probably a triangle) not on the circle.
        You'll then see the parameter in the Properties
        Dave Plumb
        BWBR Architects; St Paul, MN
          but the elevation tag is invisible on the plan and also on the general floor plan, so I can't edit it. I am not sure if it is relevant, but I have similar callout plans in the same project at the same scale, and the corresponding elevation tags appear fine on these plans.
            The other way to change this parameter is by going to the view. Under the Graphics section in the Properties of the view you should be able to see the line that allows you to change that parameter.
            T-
              You should also be able to see it from the Elevation View (not the Plan View)
              Dave Plumb
                Ok I found it on the elevation properties and it is set to Hide At Scales Coarser Than 1:5000 So I guess this is not causing the problem...
                  Any other guesses?
                    Does it's view depth go beyond your crop view boundaries? Not sure if this happens, but i do know it is the sort of thing that influences.
