Revit OpEd: Quick Tip - Trim to Corner to Join
    The Trim/Extend to Corner tool is obvious right? Pick two walls or pipes and you'll get two connect elements that form a corner. Would you think to use it to join two elements that are aligned but not connected? Try it, you'll like it!
    Before and After...
