TransactionMode.Manual Question
    I'm working through the Developer Guide samples, and I've run into a question I want to pass by you guys.
    I was able to get the Hello World sample to work without opening a project by changing the TransactionMode.Automatic to TransactionMode.Manual. However, now that I've created a PushButton for it, I can only run the Command through the PushButton after a program is open. The HellowWorld command still loads under External Tools and still runs without opening a project, but the PushButton will not operate without a project already being opened.
    Is this because of the way IExternalApplication works or am I missing something about the TransactionMode.Manual directive?
    Thanks,
    .Carl
    I believe (with my very limited knowledge) that this is default behaviour. You cannot execute any (or very very limited) command when no project is opened. In fact, you cannot even create a new project without already having a blank project opened.
      Well, I'm able to run the HelloWorld command without a project open, with only the Recent Files page showing.
      It was with TransactionMode.Automatic set that I could not do this without a project open. I'm just wondering if there is a way for Applications to be run without a project open as well.
        Nope, that's what I meant. The HelloWorld doesn't really "do" anything in Revit. Just pops up a screen. Actual "Revit-commands" cannot be done without a project opened.
          All the new Ribbon Button that I added does is run the same HelloWorld command that runs without a project open. So why does it work from Add-Ins > External Tools > HllowWorld but not from Add-Ins > HelloWorld (PushButton I've added)?
            Sorry dude, can't help you with that. I don't fully understand how it works either. I just know that every time I want to do something without an active project I am drawing dead.
