Revit wrong coordinates
    Hello all,
    We face very often a problem with the correct orientation, the place and the coordinates that our buildings should have. For example, some time ago when we exported from Revit in dwg the building was correct placed but when we exported from Revit to Navisworks the Coordinates didn't match with the correct ones, so recently we found the Navisworks settings and change the Coordinates from Survey point to Project Internal.
    Is there any workflow that we can follow when we start a new project according with the True north , Project North, Survey point, project base point ?
    Any information about these will be useful!
    Thank you in advance.
Loading...
