Moving a site
    Moving a site
    Firstly, hello :-)
    I am quite new to Revit but manage to solve most things myself. However I am having a problem with moving a site. I am having a training session next week in setting out but this has appeared before I have it.
    I set up the project and linked/shared coordinates with the Architects file. This is all working well and has been for months. The SP and the PBP are in the same location in both files.
    I have a new file from the architect, all the coords (existing topo), PBP and SP are still identical in both files. However the model has moved 1.5m within the site.
    I just cannot work out how to move my model 1.5m while keeping all coords, SP and PBP the same. The only option I can think of is to select each level and move it 1.5m which isn't ideal.
    I hope I explained that ok and it's not super confusing.
    Dear Surrey Cheap,
    Greetings to you.
    Kindly have a look at the below link related to updating shared coordinates.
    Revit OpEd: Reset Shared Coordinates Update
    https://knowledge.autodesk.com/suppo...d8a54897e.html
    Hope it's useful
    Thanks
    Venkat.
      This information might be WHY the site/survey information changed by that much.
      Loading...
