Rebar shape code changing
    In my country there is rebar shape code with letters (D, A etc). So there is need to modify revit standard codes. In most cases rebar shape code (name) should be changed.
    How is it best to do or are there some hidden consequence to have?
    Originally posted by jyrgen01 View Post
    Copy the revit standard rebar family, rename it, adjust the parameters as required and save it.
    Sent from my SM-T805Y using Tapatalk
