Key Note Issues
    Key Note Issues
    Hello All,
    We are having issues with keynotes in V17. The keynote file reloads fine but when we place the keynote it populates in the view but the corresponding note does not populate in the keynote legend on the sheet.
    Any suggestions on a solution will be much appreciated.
    Is your legend filtered in any way?
    chad
      Not sure if you can make that out? It is filtered by Key Value - begins with -
