Install error on pyRevit
    Where can I ask for support on pyRevit?
    I'm getting an error when I try to access the Settings on some, but not all of my installs
    Apparently, I can't copy the test of the error, but I've attached a screen shot
    The toolbar comes up OK, but when I click on the Settings icon, this is what I get & then I can't change any settings
    Dave Plumb
    BWBR Architects; St Paul, MN
    There is a "Report Bugs" feature underneath the first panel called "pyRevit". I just tried out Settings and did not get that error. Were you clicking on something else other than Settings to get that error?
      I have a suspicion that is has something to do with permissions, but I'm not sure how to read those errors, so not sure where to look.
      Dave Plumb
        Did you download from: pyRevit blog
        Did you complete the EXE or do a manual installation?
        You could also post an issue on his GITHUB, https://github.com/eirannejad/pyRevit/issues
        Or hit him up on Twitter: https://twitter.com/eirannejad
