Shedules per view
    Shedules per view
    Hi All
    I'm looking at quantities per view however, I can't seem to link my schedules to a view placed on a sheet. they are all on the same level and in the same area, but I just want to get the quantities of the families in the view.
    Any Ideas?
    Regards
    Nathan
    Keynote Tags are the "only view-aware" scheduable elements I'm afraid. But if you've a view filter acting on elements in view, the same definition could be used in a schedule - but it still won't account for what can/cant be seen. Dangerous business anyway.
      theres a dynamo node called " all elements in active view". Might be a good start.
        It is dangerous business that's why I made myself a cup of coffee this morning :coffee: I'm playing around with dynamo now will post a reply if I come right
        Regards
          I would suggest you probably want to do this (and BIM in general) the other way around..
          Create a means of defining what objects go into what views (Based on systems, classification/assembly codes or whatever other type of parameter you need), then generate the views and schedules to show those objects only.
          Forget about making 'drawings' and then having to find a work around that documents what is on them. Go straight to putting the information in your model and use a data driven way of producing the output.
