View Filter Overrides
    How would I go about setting View Filter Overrides? I've seen a couple threads that all use stuff from Archi-Labs but they are not in the current version. In particular I'm looking at the View.OverrideGraphicSettings node - I (think) I can figure out the rest of it.
    https://forum.dynamobim.com/t/view-s...-not-work/8401
    chad
    If you trying to turn off certain categories, I just discovered this node in a package called MEPover.
    "View.SetCategoryVisibility"
    not the same as View Filter, but it might help someone out
    Ryan Taube
    BIM Manager - Clayco Construction | Lamar Johnson Collaborative
      Nice one! That will definitely be useful, just not in this particular instance :hide::laugh:
      chad
        Cellophane,
        Sorry for the late reply I was board and going through the forums. I think you will want to look at these to nods.
        Hope this helps,
        Steven
          Konrad has added those nodes to Core now - simply look under the Elements section The syntax is slightly different, but the overall is pretty much the same.
          Sol Amour
            Originally posted by ScubaMan View Post
            Cellophane,
            Hope this helps,
            Steven
            So the flip side of the original question: How can I set the filters to a No Override state if there is already a color / line weight override? ?
            chad
              The View Class has a Remove Filter member. That may be a start. I am shooting from the hip though.
              RemoveFilter Method
