Somehow my titleblocks are wonky and are not all located at the same origin, meaning I can't copy aligned to sheet without having to do a lot of manual fixing. Is there a way to set the titleblock locations to all be the same? I can pull the titleblock X, Y & Z location but can't figure out how to reset that...
Titleblock Locations
If SetLocation doesn't work, you could simply generate a Vector.ByTwoPoints, with the origin being one point, and your GetLocation being the next, reverse the vector and simply translate the family back
Sol Amour
I had tried Element.SetLocation yesterday and didn't have much luck. Did some googling on it and found this thread: https://forum.dynamobim.com/t/spring...orking/8930/10 - in particular Jacob's response about the Element Has Location function and the reply afterwards about the API. Seems you can set it through the API but that is way over my head... Anyone know how to do that?
Hey Cellophane,
I am the one who started the dynamo forum post. I never found a way to move a reference point.
I have however moved title blocks. I am guessing the three title block location you have are all from different title blocks?
I created a script to place things on sheets. I ran into a problem that all of our title block were in slightly different location. I tried to subtract the difference from the origin but it was off by a smaller amount than 1/256" and Revit would not deal with it. Long story short I moved all of the title block to the origin in the family.
I used dynamo to draw a line from 0,0 to some point. I then manually moved the title block (in the family) to the end of the line at 0,0. They were easy to move since you can just select everything and move it all together.
This will shift every title block in your project. so it could mess up every sheet depending on how you have them set up.
Hope this will help you. If you have any question please ask. Your post have helped me a great deal over the years.
Steven
Thanks Steven.
The problem I'm running into is that I moved the title block origin in the family and reloaded, which shifted them in the project. Some were adjusted to be fixed, some were adjusted but by an incorrect value (??) and some are where they loaded in initially. I'd prefer not having to manually go through every sheet if possible...Last edited by cellophane; September 13, 2017, 08:23 PM.
Oh sorry you are one step ahead of where I thought you were.
Are you looking for a way to reposition all of your title blocks in the project after you reload the moved family?
If so do you know the distance each family moved or are you trying to move each title block to 0,0 in the sheet view?
I just did a test run and it seams to have worked for me. see image
I've got a graph that looks at all the Viewports on a Sheet and adjusts the Detail Number based on where they are on the Sheet
I added a section...-
Channel: Dynamo BIM
November 21, 2017, 03:32 PM -
I have been trying to build a macro for a bit of time now and have discovered something really weird.
The macro can create a sheet view,...-
Channel: Third party Add-Ins, API and R&D
September 15, 2014, 03:58 PM -
Hi I am hoping to make a family with "instance" parameters for its x y z location, so I can export the data to excel and update the family location...
December 16, 2013, 12:14 PM -
Does it make any difference if the lower left corner of the titleblock family is not at 0,0? We would like to have our titleblock families...August 4, 2011, 04:21 PM -
I am having issues when creating my titleblock families in Revit. I am using one of our AutoCAD titleblocks and I've deleted all the unnecessary fields...January 31, 2014, 04:24 PM
