Rounding a number in Family Parameter
    Hi All,
    I'm trying to make the below rounded to .5. The Horsepower parameter property is set to Common/Number/Electrical_Loads but there is no Project Units or anything for me to format down the rounding. Also I've noticed that when I change the rounding to other things like Apparent Load below to 0 decimals, as you can see, it still maintains 2 decimal places.
    If you're willing to use a Shared Parameter you can manage the rounding in the family, otherwise I think the rounding your referring to isn't really rounding but display rounding for schedules and the like. There would be nothing preventing you from entering .853942, for example.
    This should do the trick -- Horsepower_Rounded = round(Horsepower/0.5)*0.5 -- if you always need to round up you can change round to roundup. Similarly with rounddown.
    Greg McDowell Jr
    about.me/GMcDowellJr
      For clarification (this took me a while to figure out) dividing, then multiplying will set the rounding value in your formula. In the example above it is rounding to the nearest 0.5. If the divide/multiply was 0.25 you would round to the nearest 0.25, if it is 1 it will go to the nearest whole number.
      =1.5
      round(Horsepower/0.25)*0.25
      =1.25
      round(Horsepower/0.125)*0.125
      =1.125
      round(Horsepower/1)*1
      =1
      :thumbsup:
      chad
        And, of course, you can swap the number for a parameter and change it on the fly from within the project. Super useful.
        Greg McDowell Jr
