Type Mark (and Material Mark) linked to Sheet Number or Name
    Hello Forum
    I am looking to connect the Type Mark value of a family to the Sheet Number or Name. The reason for this is I would like to use the Type Mark to be able to set a coding standard (LT-01) and this to update the Sheet Number or Name for this sheet which will act as a spec sheet for this family. In the same way I would like to connect the Material: Mark value to the Sheet Number or Name so the material can have an individual (spec) sheet.
    Can I ask if this is possible do you know? Might it be a Dynamo job?
    Thank you very much in advance for any help.
    Tim
    Dynamo will speed up the process of moving data from one field to another but it's still a manual process.
    The only way i know to make it automatic (to begin with) is using assemblies.
      Many thanks Elton.
      Looks like a re-think on this one. Trying to link a type to an instance didn't seem like it was going to work. Thanks again.
      Loading...
