turn on/off worksets in a linked model
    wondering if it is possible to turn on/off worksets from a linked model e.g. we have a site model linked into our building model and on our site model we have a lot of trees and those trees are on their own workset in the linked model. while we are in our building model and have the site model with the trees on their own workset linked into our building model we would like to be able to turn off the workset the trees are on in the linked site model from the building model. is this possible and/or is there another solution.
    the reason for this is that the trees are slowing down our model
    Yes you can: When linking the file, you can specify what worksets to load.
    You can also manage this through the Manage Links Dialog
    Alex Page
    RevitWorks Ltd
      thank you very much
        IIRC identically named worksets turn off through links automatically.
        But don't quote me.
          But don't quote me.
          Done. yes it works.
          My small rant, using the workset to manage performance, good. Using it to control visibility in views, bad. Use filters for that.
