I'm trying to insert this titleblock in order to read the sheet name in identity data and a custom identity data parameter within the titleblock family. Now I understand that Revit would break if you put multiple views in it since it couldn't reconcile the views added to display that. So I'm wondering if I'm going about this the wrong way. How can I throw detail views onto a sheet and have it populate information based on the detail view instead of having to retype up the same information into the sheet?
What parameters to use for a titleblock to read detail view names?
That is what view titles are for...
Now you can modify a view title to include a box, but you are pretty limited on what information can be added to it.
Unless what you are showing is the sheet view, then you just need to modify a view title that will overlap the information in your sheet view.Michael "MP" Patrick (Deceased - R.I.P)
It is in a sheet view since it's a titleblock family.
If I have multiple sheets with singular detail views in those sheets, I would have to modify each individual view title for each detail view to be in the same place on the titleblock family? There is no way to automate that?
Also what about custom information? Also integrate that into the view title as a parameter to read from the project parameters? Even if I do all of that I'm still stuck dragging all view titles into the right place for say... 100 sheets?
I usually add some crosshairs in my view title family using invisible lines so I can line it up where I want it. That is for large format sheets and so all the details line up. Same principle with a single sheet.
As for doing that to multiple sheets, yeah, unless there is a way to automate it in Dynamo. Sorry, not a fan of single sheet details.
Nice thing is, you can do it once, and then resuse the same sheets w/ details for other projects.Michael "MP" Patrick (Deceased - R.I.P)
Originally posted by dylanrevitq View PostI just tried it and it sort of works. How do you get the invisible lines to snap to anything?
After a few times you can usually place it 90% of where it needs to be...Michael "MP" Patrick (Deceased - R.I.P)
When working in a view inside of an sheet... Is it possible to have a smart connection between the objects in the view and the title bocks in the sheet?...January 7, 2014, 02:12 PM
This is my problem. I am trying to have my View Title family display both the “View Name” and “Title on Sheet” parameters in separate labels....
Channel: Third party Add-Ins, API and R&D
December 8, 2010, 10:23 PM -
hello
i discovered the generic annotations and that's great!!
i'd like to create a "titleblock" (just just the round of the title...September 28, 2020, 08:27 PM -
Hi everyone.
Is there a way to have some kind of sheet groups? What I want to do is to have two sets of sheets, one of for A3 titleblock...August 22, 2013, 09:46 PM -
Managing views and view titles on detail sheets is an issue I've been working for ages. Below is a method I've developed to make things work a bit easier....
Channel: Tutorials, Tips & Tricks
July 7, 2011, 08:38 PM -
