Isolate Elements in View.....Permanent?
    Once you have selected some elements or families in a view, you can those "Isolate Elements" and then apply it "permanent" for the view...
    But its just a "at this moment"-kinda permanent...
    Once a new element gets created its also visible in the "Isolate Element"-view...
    Isn't it possible to really isolate elements permanent...permanent?
    Sendt fra min SM-G935F med Tapatalk
    Isolate is not 'isolate', ..it is the opposite of 'hide'. In other words 'hide the elements that are in database NOW, EXCEPT..'.
    That is the reason behind seeing NEW elements. I think it is fair that this logic can be discussed..
      Yes! Its called a Filter
        Many people forget the power of the Selection Filter. As shown in the image, after you select the items, click the Save button under Selection and name it. Now you can apply this Filter to any view or view template. I use this often for certain applications.
        These are saved under Filters so it's always there to reuse.
        Tannar Z. Frampton ™
        Frampton & Associates, Inc.
          Thank you all for your reply...[emoji3]
