2017.2 error when closing out
    Suddenly in the past couple of weeks I've been seeing an error generated immediately after closing out of Revit at the end of the day. Seems very odd since I've never seen it do this before the past 1-2 weeks. Now almost every day, all projects are closed, Revit window is blank gray, and I hit the red X. Almost immediately a message comes up about the program terminating but "it's okay because all projects were saved" and then asks if I want to send an error report to Autodesk.
    Anyone else seeing this?
    The problem was the DigiPara Elevator Architect 2017 external add-in. It was corrupt in some way, apparently. Uninstalled it and the problem went away.
