How to import 3ds file into revit?
    i dont find any option to import 3ds files into revit. should i first convert the 3ds to 3d-dwg file?
    Revit don't allow that kind of import, try to convert the file but IMO you must try to create the object as a native RFA file
    E.A Poe
      Hi Danezeq,
      Unfortunately the workflow is normally the other way around. Just a quick google search came up with the following:
      https://www.google.co.uk/search?q=ho...hrome&ie=UTF-8
      Of course a 3D DWG coming into to revit would be practically useless if you wanted in revit for the purpose of doing anything even closely useful with it.
      I think in such a situation I'd have to build a new revit model. And knowing how things are made in 3DS Max, I wouldn't rely on using it to trace to either, all the dimensions would be useless.
      Kamran Mirza
