Hello all,
I am attach two screenshot in order to help me to understand how the Revit works with the representation of the elements.
I have 2 columns, the fist one is cut in the level 2 and the other one is down from the level 2 (so in the floor plan I see the column projected?).
I go in the Object style and I put a thickness 7 in the Projection Line weight but I don't see any different in the floor plan (I have enabled the TL option).
How I will see the projected column with another weight? Also how I will change the grey color?
Thank you in advance!
