Lost material library path
    Hi guys, maybe this is an easy one but.....
    Recently I have an new PC and once I started to work I noticed that I've lost all the OOTB material libraries; I've already seek a little in the internet and I only found threads which talks about modify the .ini file, anyone of you knows how can I re-map my OOTB material library without modify the .ini file, of if there is a folder or hidden folder I should look to re-map my files?, I'm working on W10 and my last machine was in W7 PRO, I have Revit 2017 and 2018, I'm thinking that maybe my question is easy to solve but by now I'm pretty lost, Thanks in advance
    E.A Poe
    Solved, I just found the problem :laugh:, thanks :coffee:
    E.A Poe
      Literally no problem at all!
        yeah, sorry about that, between win 7 and 10 there are a lot of little folders and sub-folders that are re-named different and so on, so that drives me crazy :crazy:
        E.A Poe
        Loading...
