How to Material Tag Membrane=0 ?
    Is there a way to place a material tag on a membrane layer?
    We are trying to material tag a membrane in order to have it labeled in the wall section, since the membrane or paint have no thickness we tried to give the membrane a thickness but it is worsening the problem since the element is becoming thicker.
    The user Keynote is not a solution to this problem, since we want to tag the description and the Mark as shown in the attachment.
    have you looked at "Keynoting" materials?
      No. If you thicken the layer for tagging you'll need to reduce the thickness of other layers to compensate.
      Greg McDowell Jr
      about.me/GMcDowellJr
        did a quick test, material keynoting doesn't work.
        seems the only way is via API (read layer info and put into type comment etc).
