I am kinda new to Revit and I am trying to use the align dimension command to show an aligned dimension between two points- I am trying to make dimension line(30480) parallel to line AB. The outcome is that it gives a linear dimension instead of an aligned dimension
Kinda find it strange because in a similar scenario it works perfectly.
