Wall Wraps Query
    Wall Wraps Query
    Hi there. I have just joined this forum and have a query.
    I am trying to edit my window family so that the opening sizes of the external and internal wall wraps can be set independent of each other. This would allow me to accurately dimension the structural SFS openings which vary slightly from the external brick opening sizes.
    I have tried to search online for the answer with no success so was hoping that someone here might know.
    Thanks
    See if this helps: https://www.revitforum.org/blog-feed...k-windows.html
    Otherwise you will probably need to add in voids (instead of using an opening) to get the proper openings.
    chad
