When printing a sheet, the architectural model ( in plan view) is waaaay to light. I have the arch. model linked in to the project file. At first, over in the properties box, the discipline was set to Architectural. I changed that to Mechanical and that fixed some view range issues I was having but now made the grey in color. I went ahead and left it that way and made callouts for about 10 different areas. I then plotted it and found the was too light. I then changed the discipline back to Architectural but then all my callouts disappeared. All my detail work (duct sizes, tags, etc.) are in the callout views. I do not want to re-create and detail all those callout views again but if I leave it as mechanical discipline it plots out too light. Any ideas on how to keep the dark enough to plot and still see it? When I've done job with just using a CAD linked in, I do not have this issue.
Thanks in advance for any help!
