Vertical pipes change position when changing height
    Hello,
    Do someone know what the problem is, when drawing pipes horizon at -300 height and changing exemple to -200
    the vertical pipes change position (x position)?
    is there a option that could pin the position?
    Is the horizontal pipe sloped? Sloped pipe does some surprising things.
    Cody Rapai
    Democracy At Work
    I know too much about Revit to call myself an expert.
      is pipes without sloped
      • Drawing parallel pipes
        Hi, I'm working with Revit 2013, a sub program of Building design suit and I try to draw parallel pipes in my project, but there is no possibility to...
        December 9, 2016, 04:51 PM
      • Co ordination help required.
        I am doing a refurbish project and the suction pipe has a fall on it. Could someone throw some pointers on how to co ordinate Pipe when...
        June 6, 2015, 03:15 AM
      • Sloped Pipe Question
        I'm a new member to this group, it looks pretty good.
        I replied to a thread on the Autodesk Revit MEP (not the other one) group earlier about...
        December 23, 2010, 10:09 PM
      • Pipe reducer - Problem with horizontal justification.
        I’ve created a basic pipe reducer that has a justification problem.
        Horizontal pipes justify correctly, in the vertical...
        May 4, 2020, 06:22 PM
      • Slope for plumbing pipes
        As per our project requirement we have placed drainage pipes
        with 1% slope.we have set 1% slope for the placement of drainage pipe but the slope...
        April 27, 2011, 09:52 AM
