I love the error that goes:
ERROR MESSAGE: Can't obtain permission to edit the element: The central file is inaccessable. You can check out worksets at risk, but consider carefully!"
It used to happen to us when we'd import/Link HUGE autocad files. Eventually we stopped doing that, and never saw that message again. If you notice, Autocad breaks it's curves into tiny segments which causes that error.
Solution : Avoid using Autocad files in Revit Models.
So I am getting this error and it makes noooo sense whatsoever. My other views work perfectly, there are no weird template settings and the view range...
