Any way to use characters instead of just a color for conditional formatting in Schedules? Specifically what I'm trying to do is use a "bullet" from the Character Map symbol in Windows as a sheet revision indicator for a sheet index issue column as we revise the set. Right now I use conditional formatting to color the cell based on revision number, then I copy/paste the bullet in manually. Just wanting to remove a step is all, and using a cell color tends to blend too much when you have 2, 3 or more sheets in a row that have a rev associated with the issue.
Thanks in advance!
-TZ
Thanks in advance!
-TZ
