Migrating SCCM applications to a new server - do i need to edit the INI files?
    I package all of the Autodesk applications using the Autodesk packager. I create an SCCM application using the command
    .\Img\Setup.exe /W /q /I Img\RVT2017.ini /language en-us
    The INI file points to the old datasource for the old SCCM server. Do I need to change the path to the new datasource in the INI file?
    We will be eliminating the old datasource eventually.
    Yep, or they will all fail to even run.
      Thank you, Aaron for the quick response. That's what I thought....
