Cannot connect curved wall at corner
    Hi everyone
    I am having trouble joining a stacked curved wall with another wall at corner (see image). It appears that the top part of the wall (render) works fine but the bottom (brick base) is where the problem happens. I tried the wall join tool as well as trim but these either show same solution or, even worse, create a cut out corner...
    Any suggestions? Thanks for help in advance!
