how can i show in revit a wall that is shared between 2 neighbors?. In ACAD I just draw half the wall along its length (if total width of wall is 230mm i draw it 115mm) and mark with a double center line where its shared.
wall shared with third parties - how to draw?
here in the US this is called a "party wall" and there are various ways to construct them, most of which are defined by local building codes. That said, I would investigate what is required where ever you are then build the wall in Revit exactly like it will be built on the project. Or, if this is just a learning experience then Google "party wall construction" and you'll see lots of examples of the various optionsI'm retired, if you don't like it, go around!
I think Chris wants to split the wall down the center so one piece is part of one home and the other piece is part of the other. I would not do that. As Dave mentioned, build it in Revit the way it will be build in real life. So, if it is 1 concrete 230mm wall, model it as 1 concrete 230mm wall. Splitting it up will cause all sorts of issues while modelling (need to keep track of 2 walls where people expect to have just 1 and I'm guessing IFc will give trouble and scheduling will be a pita as well.
If you want to have drawings per house and really want to show just half the wall (I have never done that) just use a cropbox and place that in the middle of the wall.Company Website: www.deurloobm.nl
Originally posted by Robin Deurloo View PostI think Chris wants to split the wall down the center so one piece is part of one home and the other piece is part of the other. I would not do that. As Dave mentioned, build it in Revit the way it will be build in real life. So, if it is 1 concrete 230mm wall, model it as 1 concrete 230mm wall. Splitting it up will cause all sorts of issues while modelling (need to keep track of 2 walls where people expect to have just 1 and I'm guessing IFc will give trouble and scheduling will be a pita as well.
If you want to have drawings per house and really want to show just half the wall (I have never done that) just use a cropbox and place that in the middle of the wall.I'm retired, if you don't like it, go around!
The real reason people tend to try splitting the wall in half (in Revit) is that they are either using Groups or Links for the units or houses, and they have a bunch of walk hosted or face based items, which need the wall to be included for the content to work.
For the record, I tell my clients: Party and demise walls dont go in the groups at all. And no face based or walk hosted items in the group are hosted to the party wall. They use unhosted content for most things, and there is a reference plane at the face of the wall (in case they absolutely must use a face or work plane based family) that is in the group.
Aaron Maller
Director
Parallax Team, Inc.
Originally posted by Twiceroadsfool View Postthere is a reference plane at the face of the wall (in case they absolutely must use a face or work plane based family) that is in the group.
Sent from my iPhone using TapatalkGreg McDowell Jr
about.me/GMcDowellJr
. If it was a concrete wall between two spaces why would there be any importance to having each residence have an "ownership" of the wall?? Other than maybe graphical in which case your crop region idea would work fine.
Originally posted by GMcDowellJr View PostI assume you control the extents of the RP so they don't show up everywhere?
Is there a way to quickly align two objects so that they become parallel to each other?
Let's say that I have two walls 10' apart from each other....May 4, 2011, 03:46 PM -
Very very new to Revit.
If I draw a wall (chain selected, location line: core face exterior) when I draw the next part of the wall it starts from...March 21, 2017, 08:16 PM -
Hi guys,
It's question time again!
I'm working on a number of buildings and they all have brick cavity walls where the back wall is precast...June 29, 2013, 12:34 PM -
Hello world,
I am starting a new project that will be mostly steel construction but there are some Integra wall systems walls that I...-
March 1, 2018, 05:13 PM -
Is there any way to create a boundry wall like in attached rvt with wall/ curtain wall/ Line based family
LJU...-
September 11, 2016, 07:06 PM -
