Mechanical tempale needs only structural projects?
    Hello all,
    I have an architectural project with a steel structure in Revit 2017. Is it possible to start a new mechanical template(in order to put mechanical equipment) linking the architectural project in it?
    I want to know, if I need to link only the steel structure with no walls,facade etc.. in order to be visible the steel structure, avoiding the conflicts.
    Because in the mechanical template I cannot choose for example the roof to hide it, in order to have visible the structure that there is below to it.
    Thank you in advance!
    Maria
    The visibility of links have their own V/G overrides.
    You can select individual objects in a link by hovering the cursor over the object and hitting the tab key. It may take more than one tab.
