I'm getting hammered by this box thing today - constantly having to re-do text because of the text entry behavior. Once the drop-down appears, keyboard entry behavior changes. You can no longer use the Home, End, (Shift+Home and Shift+End also) and Ctrl+A to change the text you are entering - they now work only on the drop-down box. If the box never appears, these keys work on the text you are entering.
I wasn't able to see a setting in the .ini file - I hope I'm just missing it. Can this thing be turned off?
