The window grills show up in the regular 3D view but when I go to render it...... No grill show up in the rendereded image. Any ideas?
andersen window issue
I think those are internal grilles and, if so, the glass is too reflective to see through. Either too reflective or too dark inside so a little reflectivity goes a long way (just like IRL).Greg McDowell Jr
about.me/GMcDowellJr
Too dark inside. Just like in real life, it turns to a mirror. Renderings make it even more mirror like.Greg McDowell Jr
Originally posted by cc1012 View PostI'm a noob. Is there any easy way to move the grilles to the outsideI'm retired, if you don't like it, go around!
I know this thread is a few days old, but it struck me as odd all the same. It doesn't have anything to do with the muntins; it has to do with the glazing (e.g. its reflectivity)...IMHO. Easily verifiable by turning off the glazing visibility in the view and re-rendering. Betcha they show up fine then. Also, you could experiment with different times of day, or seasons, to get the muntins to show through (assuming your glazing has a transparency factor).
My two cents. Good Luck.
a help,
I would like to know if it is possible to create a window with a mirrored side and a normal one-
July 1, 2018, 04:23 AM -
Hi to all,
Im new in this and if some can help me.
i made new parametric window and i need insert parametric glass from manufacturer to my...-
February 16, 2018, 08:22 AM -
i'm looking for a certain window family on revit which has a fixed glass division on the bottom (pic1), while the upper glass can be opened in two modes...November 1, 2017, 09:04 PM
Hi everyone, i am just wondering how i can render glass in blue color instead of default clear glass that give black color.
i even change type...-
Channel: Rendering and Gallery
January 17, 2012, 01:39 PM -
This window family is downloaded from RevitCity. I tried removing the window frame but the glass is deleted as well. How do I just remove the metal frame,...
February 27, 2018, 04:44 AM -
