I am trying to create a tag that reads a simple number from 1 to 40 and returns another simple number for an FLS tag. I have created a lookup table in Excel, saved it as a CSV file, loaded it into a tag that I have created. The problem is, when I try to set up the formula telling Revit to use the lookup table, it tells me the lookup table is not a valid parameter. I'm attaching a screenshot of it. Is the problem that I am trying to drive information in the tag (can't be done) or the use of the lookup table (bad syntax or formatting)? Anyone familiar with using Lookup Tables, I would love some help.
Lookup Table to drive data in Tags
Hello,
My understanding of Lookups, is that they must live in the (custom) family. It appears you are trying to connect the data to a room element, which as a system family would not be able to store the lookup info. For your example of occupancy, we would typically create that as a Key Schedule, which is a type of lookup. Perhaps that would be acceptable?
Best Regards,
Glynnis
Precise BIM Data Management with 4 Revit Plugins | Ideate Software
Revit Help topic:
https://knowledge.autodesk.com/suppo...01B48-htm.htmlGlynnis Patterson, Architect
www.ideatesoftware.com
i am new to using lookup tables, and I want to know if you can use a range of reference values for the first column. I am trying to relate one ratio to...
Channel: MEP - Family Creation
July 9, 2015, 08:47 PM -
Can any one explain how to create lookup tables for family creation...
Sent from my Lenovo K33a42 using Tapatalk-
Channel: MEP - General
April 16, 2018, 05:54 PM -
Hi all,
I've been trying to teach myself about lookup tables and made a first, very very simple .csv lookup table to test the basics. However,...-
August 6, 2018, 01:51 PM -
I have been trying to import a new lookup table for a pipe fitting family, but no matter what I do it gives me the "Separator in Header is Invalid"...
May 4, 2020, 09:03 PM -
I am a long time Revit user and never had to use lookup tables. I have now done my homework and the only significant difference between type catalogues...February 11, 2018, 04:56 PM
