How to add more points or splines
    Hi all,
    I have created this form using only 3 splines (see pic) but now I wish I had used more (like 5 or 6) so I could further massage the shape plus it would also mean that when I add an adoptive component it would hug the surface more accurately.
    Any suggestions?
    Lox
    Select the Form, you will see an X-ray button in the ribbon, next to an Add Profile button.
    Use that and you will get extra options, where you can go Add Profile and then move your mouse where you need the extra profile. Use the Xray to better understand how Revit sees your form.
      Awesome, thanks!
